tensioning drive belt 97 306 td
geoff tulip
Unread post by geoff tulip »
may fan belt is screaming - before i start and make a mess of it - can i just tension it by tightening on the alternator or is there tensioning pulleys etc to worry about ?
mgoodlad
Unread post by mgoodlad »
Alternator is fixed in place and there is an adjuster pulley which goes up and down to adjust belt tension - from memory there are two alan head bolts to loosen, than a bigger adjuster bolt to make it go up or down. If you put the car up on ramps or jack up and have a good look underneath you should be able to see how it works.
Michael
1996 306 TD 78k miles
1996 106 1.5d 104k miles
arry_b
Unread post by arry_b »
Check that the belt isn't glazed or cracked, it probably is.
While you've got the tensioner undone, it's an ideal chance to replace it. It'll cost under a tenner and take an extra 5 minutes to fit.
arry_b
Oh, and you'll need good allen keys to undo the tensioner whether you just tension the belt, or replace it. Use lots of penetrating oil.
