hi guys
Has anyone had this problem the car is unlocked you go to open the boot it won,t open its acting like its locked ive had this annoying problem a few times (crawling inside the boot from the folded down seats to get the panel off inside the bootlid and flicking the linkage to open boot!) on looking at the linkage the servo motor is not pulling the lock far enough back for the outside button to engauge on the part to move the lever to open the boot. ive tried sticking a peice of plastic to the linkage that did,nt last long also ive elongated the screw hole,s for the servo motor to give it some ajustment did,nt work ethier any ideas guys.
pete...............................
xantia boot lock problem
arry_b
[email protected]
Redeye
[email protected]
update
hi guys well ive done a little mod to it and ive tried WD40 and that did,nt work so i superglued a piece of hard plastic to the release lever and thats worked a treat so now when i go to open the boot its fine again failing that i will have to get a new lock machinism
pete...........................[:)]
