BX 1.7 TDR Leaking overfueling device
devall
Unread post by devall »
hiyas, got a Lucas Cav/Roto-diesel injection pump that seems to be leaking from the front plastic cap on the overfuelling device - any ideas on this one. Is it a matter of changing the whole pump for one from a scrappy, or can it be repaired?
oilyspanner
Unread post by oilyspanner »
From memory I think theres an O ring in there and possibly a diaphragm.
Stewart
devall
I think I'll pull it out and have a look on the bench then..
x 94
Unread post by citronut »
where your fuel feed and return pipes join pump one of these banjo fittings should have a one way valve in side it is usuly a ball bearing,when it gets stuck it causes fuel to leak from where ever it can regards malcolm
devall
well the ball bearing is loose ... thx for the suggestion
