Odd power loss (306 XSi)
Linchpin
Hey guys. Im getting an intermittant loss of power, the car seems sluggish, and is "hunting" to idle sometimes. I have had the car code-read and there is nothing up on the ECU. I have noticed, that under the hood there is a pipe with a split on it. I think its an oil breather or something like that? Basically there are 2 pipes next to each other, coming from the top of the engine down the front, together, and they are shaped pipes in a kinda S shape. Any idea if one of these pipes can cause problems like this? Its the 16V XSi model, i think its an XU engine or something like that (the 140bhp one). thanks for the help, i can provide more info on the problem if anyone wants to help out
Linchpin
Just to add, on this piccy (not mine)
http://www.306gti6.co.uk/mypeugeot/modi ... engine.jpg
its the 2 pipes close to the "16V" on the head. The left hand one is split on mine.
Kev.
Kev.
rossd
The two thicker pipes on the right hand side, or the narrow pipes on the left? The right hand side ones are breaters and those on the left are the fuel pipes. Yes, a split breather here would most probably cause rough running, it certainly did when they went on my old 205. I'd do a temporary repair with some duck tape or similar and try it from there. (Note, a repair like this wont hold, you will have to replace the pipes....)
Linchpin
rossd
Linchpin
Linchpin
Linchpin
Linchpin
OK!
Problem solved. Got very annoying with Engine hunting on idle when wheels turning, was cutting out all the time. Got a mechanic mate of mine to remove the throttle body and it was absolutly filthy inside. 10 mins of a good spraying with Air Intake / Carb cleaner and the jobs a goodun! Still getting a slight judder when pulling off when the engine is warm, i think this is due to the induction filter drawing in warm air from the engine, so a custom design is on the way! Ill take some photos and post before / after results once its done.
Cheers for the help (as usual!)
Kev.
Kev.
rossd
Linchpin
