Xantia TD ABS (i know!)
AndersDK
Unread post by AndersDK »
That 1423 ohms on ROS is indicating a near future problem.
Get an OK test from the ECU by connecting a 1K ohms resistor instead of the sensor - on the faulty ones.
Can not access your account - you must notify Jon.
JohnT
Unread post by JohnT »
I had a similar ABS light problem. I tried two replacement ECU and the result was the same. It ended up being a faulty sensor, the usual one.....nearside front. Been OK since.
