xantia fuel filter leak
j_roc
Can annyone help me with my 1994 Xantia 1.9 td - ive not had the car long and fuel is leaking from the filter housing lid. Should it have a rubber seal or not? also the oil pressure warning light, the stop light and the suspension pressure light have come on all at once! A great car after my old Ford Orion but god is it dogged with problems.
ITMA
The rubber seal is on the filter itself.
If you have checked that the screws holding the filter body lid are tight I would suggest checking the filter: a) Could be in upside down (rubber seal end should be at top under lid); b) Rubber seal may be damaged or missing - or even no filter in there.
If the filter has not been replaced recently it would be worth getting a new one before you investigate.
- x 94
- x 94
j_roc
Thanks for the info. I took the housing lid off, there was a filter in there, but it seemed a loose fit (moving around a lot). Also can annyone shed any light on the oil pressure, STOP and suspension pressure light coming on altogether as soon as the engine starts? This is my first diesel and im still on the learing curve - ha ha.
nick
j_roc
nick
j_roc
Does annybody know where the earth for the items mentioned above is located? Why do i get the notion in the back of my mind that the head gasket is on the way out (would explain the low oil pressure, although it aint loosing any oil or water externally). I looked inside the oil cap and its fine - no mayo or water in the oil, and there aint no oil in the expansion tank, although there are bubbles in the tank (about the size of a pin head) when the engine is running - pressure cap removed. Any ideas welcomed as im losing my patience and seriousley thinking about buying another Ford Orion!
