Xan 19td manifold bolts ,how many ????
basil
Unread post by basil »
I'm starting to do my hg so I am removing the manifold , so I do not spend time looking for bolts that are not there how many bolts are there on xantia 19td 95n[?][?]
So far have removed 6 allen/2nuts(with stud) can see 2more nuts[:(]
________
Michigan Dispensary
basil
Have found the answer 1 more bolt right in the middle[:(!]
Total 9 manifold off[^]
Ooops just counted up total 11[:I]
Only 7holes in the manifold,what else have I undone[?]
________
Herbal Health
oilyspanner
Unread post by oilyspanner »
Had the short Allen bolts on the ends? inlet manifold has 13mm hex bolt bottom centre you only need to loosen it, leave the nuts and studs/spacers until inlet is off.
Stewart
oilyspanner
Nuts and spacers hold the exhaust manifold on, dont forget to undo the steel turbo oil feed line top and bottom, catch the little filter inside the bottom one, also turbo oil return.
Stewart
basil
The extra bolts were holding on the turbo manifold[:I]
My next task is to undo the bottem pulley bolt [:(],any tips please[?]
________
HAWAII MARIJUANA DISPENSARY
oilyspanner
If the plastic covers are earlier ones (held at top with over centre clips) then the bottom part can be removed allowing timing belt to be changed, if later covers carefully break bottom part between mounting bolts and remove in two pieces, change belt again[8D]
Stewart
basil
The plastic covers are the bolt on ones[:(],but I have managed to remove them only breaking a bit off the right hand top one[:(]
Have managed to undo the crankshaft pulley[8D],I ended up using a long pipe over a socket bar which was resting on the ground then briefly using the starter(a last resort[:(])but it worked[:D]
Next question I have put a bolt through the pulley on the diesel pump to stop it from moving will this be stong enough[?](it is too long to tighted up against the pulley)
Look forward to replies[:)]
Update-have removed cambelt,pulley did not move[:D]
Now trying to remove head,can get rhs to lift but lhs is not moving[:(]
I think I have removed all bolts
________
Marriage Advice
