Xantia TD. Ticking about once a second, will replacing it sort it?
Thanks to those who reply!
Fast ticking suspension pump? replace??
mpr1956
- x 94
bxbodger
As with the other replies, it does sound like the accumulator sphere is flat!! They are a cheap and easy item to replace and should be considered as a consumable item-do it quickly though, because it puts a lot more strain on the pump, as when the accumulator sphere can't supply the pressure for the system the pump has to do it all- thats why its ticking so quickly, the pump is having to work very hard to compensate.
- x 1238
