Trafic misfire
turbot
Trafic misfire
Unread post by turbot »
My 1993 T1400 Trafic has recently started misfiring. It starts fine and will run on the choke, but when its warm ( choke no longer needed) it misfires, usually using medium throttle, particularly noticeable up slight hills. It doesnt seem to happen on light throttle openings
I have changed plugs and rotor arm, yesterday, I used a carb cleaner spray to clean the inside of the carb and it seemed to run fine for a while, then the misfire returned.
Any ideas?
allan
arry_b
Unread post by arry_b »
Plug leads.
JohnT
Unread post by JohnT »
I had same problem it ended up being the flywhell sensor which provides the engine spark timing. A common fault on these. Located on the rear of the gearbox under the dizzy.
turbot
Looks like it was the plug leads. Changed them and its running sweet as anything again.
Thanks arry_b
