HELP!! Spark plug thread crossed.
macaroni
Brat and blast. I was just checking the condition of the spark plugs on my Xantia Activa and number 3 got it's threads crossed. It goes in about 2 coils and no more.
Does anyone have any tips to sort this out or is it head off time?
I though about trying a new plug.
I hate petrol cars, give me compression ignition anytime.
paranoid
Richard Gallagher
macaroni
fastandfurryous
- x 4
when you come to refitting the plug (or any plugs for that matter) if you jam a length of old fuel hose (about 6") over the ceramic, this grips enough to be able to do the plug up, but not enough to strip threads. Use the length of hose as a handle, and do up the spark plug until it needs nipping up with a socket. This method has saved me dozens of stripped threads in the past, especially on recessed plugs that are hard to reach.
macaroni
ITMA
Use plenty of grease on the thread chaser. Take it carefully, allowing plenty of time to do the job, and work the chaser in only about 1/4 turn at a time before backing out and cleaning off, re-greasing and inserting again. The swarf (metal particles) will stick to the grease like the proverbial to a blanket.
Work slowly, don't use excessive force and you will eventually be able to easily run the chaser right down the threaded hole.
Finally use a small screwdriver or similar in a piece of cloth to make sure that all the swarf has been cleared out of the thread and around the seating.
I have saved more than one "head off" job by this method.
Best of luck.
Best of luck.
ActivaV6uk
- x 1430
macaroni
Homer
- x 16
macaroni
Kowalski
To recover the swarf, with the piston at the bottom of its stroke, you pump a load of grease down the spark plug hole, so it sits on top of the piston. After you've finished drilling, you turn the engine over by hand so it goes up to TDC and pumps the grease and swarf out. Then you've got to poke about and get as much of the grease out as you can to avoid hyrdaulic lock type problems when you start the engine, and it'll smoke pretty badly for a while too.
macaroni
PeterMann
I've successfully repaired damaged sparkplug threads by helicoil method without removing head. Use plenty of grease on the thread cutter, backing out after every half turn advance, and clean off the swarf and reapply grease before cutting a bit further. After can run a plastic tube around inside the cylinder with vaccuum cleaner, pulling any debris that might have escaped off the cutter tip, although this is probably not necessary.
