Xantia rear number plate
FatController
Unread post by FatController »
Hi all
just a quickie. Hows the rear number plate attached (and removed) from a 1995 Xantia hatch ?????
Is it just copious amounts of sticky pads, or something more sinister ? Whats the best way to take it off ? I need to replace mine, and have only got 48 hours to do it !!!!!
Thanks,
Lee.
martyhopkirk
Unread post by martyhopkirk »
Lots of sticky pads.
Use some fishing twine or nylon line to slip behind the plate and slice through the sticky fixers. Gentle warming with a hairdryer first works wonders too.
Then clean off the excess black sticky bits before putting a new plate on - and warm the fixers on your new plate before sticking to the car - they will adhere better.
jeremy
Unread post by jeremy »
Sounds like that great friend of the precision engineer - double sided tape!
surprised it hasn't done the job for you itself already.
jeremy
