Xantia 1995 TD Hatchback rear washer
soupy_sam
Unread post by soupy_sam »
The rear washer on Hatchback Xantia is not working, the wiper works and the water pump makes a noise, but no water at all.
Are there any tips for fixing this please?
AndersDK
Unread post by AndersDK »
Try first a needle in the jet to clean any matter here.
mezuk04
Unread post by mezuk04 »
There is water in the tank aint there....as mentioned before try a pin.
Regards
jeremy
Unread post by jeremy »
May need to remove the jet - probably pulls out but don't loose the pipe! We had longstanding but not very important problems with the rear wash on our 94 ZX and I found a lump of crud inside the jet itself. I'd been unable to clear it with a pin or wire and presumably this was crud from inside the tank of somewhere that had lodged there. I flushed the pipe by running the motor with the jet removed and put it back and all seems well now.
Jeremy
