ax disc wear = sorted now
gardenpeas
Unread post by gardenpeas »
got a new set of boots on front of me 1.0 ax spree yesterday from national (BOGOF) they said the discs are worn [:D] "whatever" i said, but how thin can they go? how do u know when a new set is needed? it still stops well enough at mo
lighteninguk
Unread post by lighteninguk »
if you got a garage to do them, then well, why didnt you have the disks done at the same time, in the long run your gonna have to pointlessly pay double labour in my view (although my view isnt nessisarily the clearest :P)
gardenpeas
not got the money sadly for discs got a kind uncle who does those bits not a big chain garage
just won't the technical info on what a new disc is and a knackered one
lighteninguk
just found a good website for brakes details etc....
assuming your ax is a 1.0 from between 86 through 98....
your ax brake disks are as follows...
Solid
3 Bolt holes
238 Diameter
132 Hub Diameter
29 Height
8 New Thickness
7 Minimum Thickness
and by the looks of things the measurements are in mm (millimeters).
also thats their brake disks, which look a bit special.....
www.ebcbrakesdirect.com
Edd
jeremy
Unread post by jeremy »
New discs are probably £9.95 from GSF. (+ VAT of course)
I had trouble with the front brakes of our Zx for awhile. I replaced the pads when we got it and wondered about the discs but they looked marginal so I left them. brakes smelt horrible with new pads and never seemed to work very well so I bought new discs (about same price as AX) and eventually got round to doing them and pads. Didn't think old ones looked bad even after a further 10,000 miles and thought I'd wasted my money but I did notice a band of polished rust in the centre of the disc where there had been a difference in pad size!
New discs were much better and I think the band of rust prevented the first set contacting the disc properly. Moral - stick to one make of pad or cut off any surplus on new ones.
Jeremy
gardenpeas
might be getting them done then, it needs an oil change etc and aux belt so i'll add discs to the list
cheers for the help
gardenpeas
it stops now yay no squeaking noises discs had 7.3 mm so was some left but the difference it's almost good now
cheers for all help
