Xantia info, snippits
ActivaV6uk
Unread post by ActivaV6uk »
Ok I managed to find a few useful things out this weekend but some of them are a little obscure so its more for info than any real use.
1 if you own a 2.1TD, V6 or a CT and get a hum/rattle from the car whilst slowing down using engine breaking or using the lower end of the rev range. Its not the commonly thought lose heat shield, it is in fact the drivers side engine mount links, these cars all have a set of links to the inner wing as well as the standard upper engine mount these slowly fail. This may seem like a useless piece of info but out of 7 Xantia Activa’s that I see frequently 5 have this fault! It’s doesn’t seem to be mileage based either its down to age!
2 the Xantia keypad immobiliser. Doubt many of you have looked for info on this but its almost non existent. I can now tell you how the coded side of things work, the pad sends a serial data stream of 1 bite this contains the immobilizer code and another piece of info. This with the right cable intercepted can be read via a nul modem and a pc (guess what I will be up to very shortly). The wire to the ecu changes depending on the ecu (it’s not a common pin for obvious reasons) the pin from the pad is always the same however (will find it out again and post). The bad news is that the code can’t be read from the ecu you actually have to over write the old ecu's code and then unlock the ignition. To break the ecu’s code you would have to continually enter the possible bite after the ecu locks after every 30m lockout period with 3 wrong attempts. (so in fact you may as well just keep trying to enter the code on the pad)!
Andy
Homer
x 16
Unread post by Homer »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ActivaV6uk</i>
<b>Now</b> you tell me.
So, I didn't have to put up with it for the last year.[:(]
Sounds exactly the problem I was having, a buzz which sounded just like a loose heat shield or a heat shield touching something. At 2000 to 1500 rpm when engine braking.
Oh well, whoever ends up with it, that's the biggest problem solved.
ActivaV6uk
Thats exactly what that is! annoying isnt it! 2 of the activa owners with this problems are so sick of it they were talking about selling there cars!
Andy
