Xantia 19td 95n
Help I have got a big oil leak it looks like it is from behind the cambelt cover.How much do I need to remove to take this cover off[?]
Do I need to take off the top engine mount[?](if so how[:(!])
Any ideas as where the oil may be coming from[?]
________
Glass Bongs
Quick help please
basil
Quick help please
Quick update I have got the rear cambelt cover off and it looks dry.
The engine looks to have oil from just below the starter area,also just below/behind the injector pump.Are there any oil pipes/known leak points in these areas?
I dont want to think about a head gasket leak.
________
HOMEMADE VAPORIZER
________
HOMEMADE VAPORIZER
fastandfurryous
- x 4
np
basil
I had a quick look at the dipstick/breather pipe area but it did not look too oily[:(].
Are these pipes commen to 19 td other engines ?,peaugot[:I](dodgey spolling)dealer nearer to me.
Thanks for the quick replies
________
MEDICAL CANNABIS
________
MEDICAL CANNABIS
- x 1431
Basil,
Hate to be the barginger of doom, but, does this look / sound familiar:
http://www.andyspares.com/discussionfor ... C_ID=10087
Just started one day no warning. Could only have been the headgasket, to leak that much in that location.
Hope this doesn't spoil your day too much!
citroenzx
surely there would be a noticeable difference in performance if it was coming from the head gasket, ie lack of cylinder compression? when i had oil around that locaition on my zx it was the engine breather pipegetting blocked, the pressure built up and when it released it forced the oil out into the engine bay!
- x 1431
Nope, no loss of performance, just the oil leak. The oil feed to the head is just there on that corner of the block, so it's possible for that part of the gasket to fail and leak oil to the outside without losing compression or getting gasses in the water. Mine was dripping every second or so even with the engine just at idle. Leaked about 1 litre of oil over 60 miles - not very socially responsible! I only discovered it because I spotted the wet patch under the car in the works car park.
citroenzx
basil
I have cleaned the area behind the injector pump/cambelt ,started engine then saw oil coming out[:(][:(][:(].HG leak cofirmed[V]
I know cries of 'touch ye not oil of the serpent'will be mutterd but has anybody use K-seal/Seal up as a fix[?](Its a million to one chance but it might just work)[:I]
Thanks (Boo Hoo)
________
Medical Marijuana Card
Thanks (Boo Hoo)
________
citroenzx
wrinklet1
AndersDK
The cylinderhead has warped because of hot spots - in turn caused by too low a flow in the cooling. This means at one end the head has a gap from the block which the headgasket can no longer fill out.
As the oilways are outermost - first symptom would be oil flowing out.
You should concentrate on the cause of the HG failure.
Most likely the radiator is clogged internally by sediments thus slowing down the coolant flow.
A HG replace work is the only cure. No leak stoppers can ever solve the problem - not even for a day.
