Drop links
randomx2
Drop links
Unread post by randomx2 »
I think I have a solution to the rettleing in the front of my Xantia, Im almost sure its a drop link that is shot, Is this a diffucult procedure. I presume just jack up front and replace. Does Hydr system have to de-press to do this ?
cit
lesoxo
Unread post by lesoxo »
No, its not too difficult.In fact if you look at the end of the bar you will find a hole for an allen key.To be on the safeside keep the suspension pressured (I even put a jack under the wishbone to stop the balljionts spinning).Be warned , I find when you do 1 you can hear the other rattling
