Hi, Anyone know how easy it would be to fit a volcane interior , including rear speakers into an N reg.1996 Avantage. There appears to be several wires going underneath the current front seats.
Any replies gratefully received![8D]
FITTING VOLCANE INTERIOR INTO AN N REG AVANTAGE
James.UK
Those wires wont effect anything, the elec window switches just unplug and stay in place, just make sure you undo the rear bolts on the front seats first.
You may have probs with the seat belt floor fixing on that model though? somthing to do with being able to pull off slowly when in a collision? There are none on mine so I didn't have that problem..
Whilst you have the door cards off give any moving parts a good coat of grease, you can easily replace the plastic covering sheet and keep it in place with some bouble sided tape.
Also make sure the rear seat still slides easily after you bolt it down, its easy to get the central runner slightly out of line..
I'm off on hol in the morning, so good luck with it.
FDV
