pug 306 plip key, how do I reprogram a 2nd hand ke
bonzo
I have a 1995 306 Diesel Turbo, the plip key gave up about a year ago so I simply would unlock mthe doors manually.I recently had reason to disconnect the battery,which, when I reconnected the battery the alarm went off.To overcome the alarm problem I have removed a rlay from under the dash.I then contacted the main dealers and was told I need a new plip key at a cost of £90,but I was advised by the spars dept that if I get a secondhand key which is exactly the same visually it can be re-programmed to my vehicle. Now the problem, How do you re-program a used plip key?. Can anybody help please.
derrick013
bonzo
paul_hdi
paul_hdi
derrick013
paul_hdi
