Hallo,
I am going to change one of my front brake calipers(I have an lhm leak from behind the rubber boot).Am I right in thinking that the brake cicuit will not have any pressure in it[?]I don't want a high pressure lhm shower
Is the brake hose a commen size[?](If I need to change this as well)
________
Motorcycle tires
Xantia brake caliper change
Niek
Homer
- x 16
- x 1449
It will be a special brake hose to withstand the LHM, so make sure you get the right one. Since you have to remove the caliper to change the brake pads, a caliper change on a Xantia should be easy. There is a repair kit availble for the Xantia calipers, which should contain the approriate seal to fix your problem.
basil
Where can I get a repair kit from? I have looked on gsf but could not see any.
Are any other models (zx,xm,bx) the same? Mine is a bendix type 95 xantia (266mm disc I think??)
________
Smoke Kills
________
Smoke Kills
BX-Basis
If the LHM leaks out behind the rubber boot over the handbrake mechnism, there's no chance to repair the caliper. This usually happens, when someone tries to push back the brake cylinder without turning it. Repairing a brake caliper with handbrake mechanism is not as easy as repairing a "normal" caliper. Fitting a new one is highly recommended.
basil
Thanks for the replies the lhm leak is from the rubber boot so it looks like replacement rather than repair.
________
No2 Vaporizer
________
No2 Vaporizer
