1989 1.6 Peugeot 406
For those that aren't familiar with the 405 clutch pedal, it has a plastic socket that the clutch cable end feeds into and is then secured with a metal clip
The problem i'm getting is generally from standstill ie 1st and reverse when you put the pedal to the floor, the cable slips through the cable end clip, dislocating itself from the pedal, if i lift the pedal up by hand it clicks back in. Could this be as simple as just a sticking cable (it doesn't happen all the time) or does something more sinister lurk within the clutch.
405 clutch cable dislocating itself from pedal
PowerLee
Hi
It sounds like the metal clip is about to let go & leave you with no clutch.
Try fitting a new plastic pedal stop & metal clip, Your talking less then £5 for both bits at a Peugeot dealer.
The fun parts fitting it, Its a bit of a fiddle to do, Some long needle nose pliers are a god send with this job.
flux
flux
