I have a K reg 405 1.9 turbo diesel, 209k miles, I got this car 2 years ago because I needed a cheap one quickly, it is probably the most reliable car I have had and I have had a few, I don't know the history of the cam belt but I think it is time for a change, a local garage quoted me £130 for a belt change, but couldn't guarantee the belt unless they change the whole kit at a cost of £247, what does the kit consist of, is £247 a fair price, I have changed ford belts before but looking at this one there don't appear to be much room, I know the dangers of leaving it I also know the dangers of attempting it and messing it up. Any help and advice would be appreciated.Many thanks
ssm
btw great forum
405 cam belt
Dave Bamber
ssm
arry_b
I've just done the same job on my ZX (which being a non-turbo is a little easier to get to). No special tools needed if you time the engine by marking the sprockets and old belt, transferring the marks to the new belt, and fitting the new belt to line up to the marks you previously made on the sprockets.
The hard part is meant to be getting the crankshaft pully bolt out, but I had no problems (22mm six sided deep socket). Getting the spring back into the tensioner was a small pain. Cleaning the old water pump gasket off of the block took me a while - Tip, use a window scraper that holds a stanley knife blade.
All in it took me about 3 1/2 hours without a manual, including flushing and bleeding the coolant afterwards.
arry_b
BTW, unless yours is making a noise you may not need to change the rollers and water pump.
I'd mark it all up and take the belt off, then check the rollers and pump. They may be perfect and not need changing. That's one of the advantages of DIY, you choose what needs doing - not what the garage wants to try stitching you up for.
If it's just the belt, then it's much cheaper and would be a quick job - couple of hours max.
ssm
fastandfurryous
- x 4
Doing this job, you must time the engine. To do this needs 3 m8x50ish bolts, and an 8mm dowel. The 8mm dowel fits into a hole in the crankcase flange behind the starter motor, and locks the chankshaft at Cyl 1&4 TDC. Two bolts go through the injection pump pulley and into the bracket, and one bolt goes through the camshaft pulley and into the head. You must fit these, as it is very easy indeed to get one of the pulleys a tooth out. Haynes BOL is reasonably accurate for this job.
I would recommend changing the coolant pump while you are there unless it looks very new indeed. The tensioner rollers are usually fine, just give them a spin and see what they sound like. Any rough-running or play means change them.
Luckily you have the earlier type of cambelt covers that clip on. These are easy compared to the later bolt-on ones.
You will undoubtedly find that the turbo inlet pipe above the cambelt guard will get completely in the way. I recommend removing the intercooler (2 minute job) and tieing the turbo feed and outlet hoses out of the way, it makes more room.
Otherwise, a straightforward job. Make sure the jack you use to hold the engine up while the mounting is removed cannot slip, as not ony are you likely to injure yourself, the alternator/power steering pump will go through the rad, which doesn't come highly recommended!
David.
David.
ssm
thanks mate - yes i have got , and read the manual, trust me i have read it over and over again, the more i read it the more convinced i am i should go for it, i shall change everything as a matter of course, now all i need is the time, probabley next weekend but i shall certinaly post results, thanks again
ssm
ssm
np
PowerLee
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by np</i>
All the garages quoted me 4 hrs labour to change just the cam belt on my Xantia.Room is very tight on the Xantia,might be better on a 405.Gives you an idea of time scale though.Good luck.
I thought the room under the bonnet of my 405 was a little tight, That was untill I looked under a Xantias bonnet.
I wouldnt want to work under the bonnet on a Xantia, A 405s bad enough some times, lol
np
fastandfurryous
- x 4
np
fastandfurryous
- x 4
arry_b
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by fastandfurryous</i>
Doing this job, you must time the engine.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Not if you mark the belt and pulleys (tippex). transfer the markings to the new belt, then replace the belt so the markings on the pulleys line up with those on the new belt.
Much easier.
Much easier.
