I have a 1997 Series 2 XM 2.5TD which has developed intermittent faults on speedo and AC.
Speedo works until engine gets to nominal temperature and AC sometimes just doesn't start. Today, after 10 minutes of driving, beside the fact that AC switch was ON all the time, AC suddenly started working????
Is there any relay or something that's connecting these two problems?
I.
Speedo and AC problem
goldfinche
xm-2.5td
goldfinche
Yep it appeared to power the compressor clutch.The colour was green relay and the open circuit wire was the black(thin) wire.There were some other bad contacts that were found at the same time.By the side of the fuse box under the glove box there were some heavy plugs and sockets coloured white that showed evidence of burning.,also just by the battery there is a small fuse box that can cut the air con and fans iirc it does tend to burn up.
Good luck
Geoff.
Good luck
Geoff.
goldfinche
ghostrider
sounds like the same problems that crop up with Xantias, beraing in mind citroen's love of tranferring problems / design faults between cars, try looking at tha Xantia solutions, things will be in different places but I'd almost bet that the whole thing is essentially the same as the Xantia
Pete
________
Mexico hotels
Pete
________
Mexico hotels
