I am changing the cambelt, waterpump and tensioner on my Activa, and after reading Haynes, was wondering how to tension the cambelt correctly. Haynes states a primary tension by twisting belt through 90 degs twixt finger and thumb and subsequently using a Citroen gizmo to correctly tension it.
Can somebody advise me on the correct tensioning of the belt, please?
Is it possible without the Citroen gizmo?
Cambelt tension
alan s
- RIP 2010
- x 6
The twisting technique you'll find is the method they use.
If they have a tension checker, on some models it's impossible or almost so to fit it to the belt with the engine in the car and even on the ones where it is used, the norm is for them to retest it after the tension checker has been used and if in doubt, give they it a tweak one way or the other.
It's Citroen repairers and the belt makers way of covering their backsides if the belt breaks.
You say an Activa so presumably it's a 4 cylinder version as I understand the 6 cylinders are somewhere between a nightmare and a work of art to change and I'd suggest you do a search on the forum before you start if that's what it is.
Alan S
Alan S
oilyspanner
Another one that has been problematic on 1.6 and 1.9 8 Valvers in BX and Pugs is the horrid tensioner, the BOL mentions re-tensioning the belt after 500 miles if a new one is fitted, this is absolutely essential and awkward, these belts can fall off after 500 miles! why they did not use the lovely automatic spring ones like the diesels I dont know[}:)]
Stewart
Stewart
alan s
- RIP 2010
- x 6
oilyspanner
Alan, yes they are a pain, the mechanism is not obvious, requires funny tools, from memory some kind of square key/small adjustable spanner and never seems to feel right even when it is, then its on the rear of the engine facing the wrong way and surrounded by razor sharp bits, fairly normal Citroen I suppose[:)] Anyway off to swap my turbo now, another fun procedure.
Stewart [:D]
Stewart [:D]
ItDontGo
oilyspanner
madasafish
