Manic revcounter
willum
Manic revcounter
I have a 116K '94 Xantia 1.9TD SX, owned from new. Anybody any clues what is causing my revcounter to do the wildthing? [}:)] It indicates the wrong figure, lashes back and forth from zero to 5K, doesn't work at all sometimes, and on occasion lashes about in time with the wipers or indicators. Occasionally the "water in fuel" light will accompany it and the speedometer sometimes doesn't work for about five minutes when ten minutes into a journey, then works fine for the rest of the day. On more than one occasion the speedo and revcounter have flicked around with just the ignition on and the engine not running.[:(]
- x 1240
The usual problem with rev counters is a poor connection, usually where the lead from the TDC sensor joins the loom, you should find the sensor just above the gearbox where it is bolted to the engine, there is a 2 pin plug/socket arrangement, water gets in and it corrodes. Take it apart, clean the pins and smear them with grease. The speedo and rev counter will sometimes "flick" when the ignition is turned on because it is producing an electrical impulse which meter's interpret as a signal from the appropriate sensors. As it seems to be upset by the use of other electrical equipment, you may have a bad earth connection somewhere.
willum
JohnT
SHEMAR
Does anyone know what the resistance of the rev counter pickup should be? GSF sell new ones but I don't know how to diagnose a defective one, taking the dash binnacle is a bit fiddly,if you can eliminate this item first. I've got the same problem. If you do take the binnacle out, change all the lamps as older ones left in place will have a foreshortened life, due to the extra stress placed upon them when new lamps are placed in the same circuit, then its out with the binnacle again !! - I know, I was there!!
