Borrowed the wifes Scenic today and the display isn't showing anymore. I can see the time is still working but nothing is lit up. The CD/Radio display is still fine. Any ideas what could be up and if its easy to fix !
Cheers
Megane Scenic Clock/Temp Display gone !
Stuart McB
cerbera
Stuart McB
Sorry for the long delay but here goes.
Remove the top of the facia, above the display, by removing the speaker grills and speakers and then the retaining screws. I't got clips as well but should come away. Then remove screws from arounf the display, remove wiring connectors and then you should see the bulb access.
Hope this helps.
Hope this helps.
cerbera
