I've got a nasty knocking/clunking noise from the front end when going over bumps. I've replaced the front lower suspension arms, anti-roll bar, suspension struts and top mounts and it's still making the noise. It's very loud, as people turn around and look when I drive past. I've run out of ideas. Help?
Laguna 1.8 1996 (N Reg)
Help - Knocking/Clunking
JamesQB
- x 5
When I had this problem it was due to worn lower suspension struts, but since you've replaced them, it can't be them. Broken or loose engine mount perhaps?
Have you tried getting the car on axle stands, removing the suspension struts and then moving the front wheels hard up and down to see if you can make the noise occur?
Something you could also try is to have a friend walk alongside the car (if this also happens at very low speed) with the car bonnet up and going over a bump, as they may be able to tell whereabouts the clunk is coming from... just knowing the general area could help.
bwellard
