Removing sphere the easy way.
JohnT
Unread post by JohnT »
Get an old seat belt webbing. From the eye bolt fixing cut the belt about 2.5 foot in length.
Aquire a sheet of abrasive material, like those used on belt sanders with the coarse grit, wrap it around the sphere.
Then wrap the belt around so the eye is facing the right direction, place a srewdriver or bar through the eye and dig the end of the blade in to the belt material and lever the sphere 1/4 turn whilst under pressure and chassis supported.
Release system pressure and spin it off!
I have done a number, and this has worked every time.
John.
