Xantia 1.9 1995 Manual Door mirror
soupy_sam
Unread post by soupy_sam »
Ho do I change the passenger door mirror it all seems to be connected together cable broken inside door?????
Is the mirror cable etc one unit to change???
np
Unread post by np »
As taken from the B.O.L.
1,Remove door trim panel.
2,Peel back the top front corner of the plastic sealing sheet to expose the mirror adjuster cable grommet,where aplicable.Pull the grommet from the door panel.
3,Prise the mirror trim plate from the corner of the door then,where aplicable,prise the alarm sensor from the clips on the trim panel & withdraw the trim plate.
4,Unscrew the 5 mirror securing screws,& withdraw the mirror from the door.Feed the adjuster cable through the door as the mirror is removed.Note the routing of the cable to insure correct refitting.
Refitting is the reversal of removal,but ensure that the adjuster cable is correctly routed & reconnected.Then refit the door trim panel.
Hope this helps.[:)]
