Alloy Wheels for Xantia
dougiefowler
Unread post by dougiefowler »
Is it possible to fit 15 or 16" alloy wheels to an Lreg Xantia due to the suspention lowering when car is not being used.
pwatson
Unread post by pwatson »
I'm no expert but since our HDi has 16in alloys and you can still put it on "low" setting I can't see a problem. Wouldn't you also use low profile tyres so the overall diameter would be the same? Or your speedo would also be out - or have I missed the point?
PhilW
Phil
autogrin
Unread post by autogrin »
I have 7,5X16 on my 1994 Xantia, and there is no problem at all!
But I want to know if 215/45 is a OK size, and which tyre-pressure I should use?
