what kind of sound would it make? UPDATE
oscarloco
Hi
Some days ago my ZX started making a kind of "whirring" sound. I suspect it could be the throwout bearing. But the question is. if indeed this bearing is worn, would the sound stop by depressing the clutch?
Currently, the sound does not change with the clutch pedal deppressed.
AndersDK
The clutch release bearing would tell you very clearly - WHEN you press the pedal.
If you have a constant whirring following the engine revs, then I suspect you could have a worn bearing in the cambelt area. Could be the waterpump or the tensioner.
You should definately investigate further the cause of the noise.
lighteninguk
arry_b
oscarloco
Well, indeed I hear it in the lower part of the engine bay. I haven't had time to check from under the car but the water pump has been recently replaced so that rules it out. And the noise seems to go away with revs (altough I think engine and road noise covers it up) and sometimes it dissapears when the car is cold.
On the other side, the cambelt was replaced in December at around 150000 Km and I suspect the tensioner has never been changed.
I will check it tomorrow.
Thanks for the advise.
alan s
- RIP 2010
- x 6
oscarloco
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by alans</i>
Not just the cambelt rubbing against the cover by any chance?
Alan S
Good sugestion, I will check that first.
Alan S
oilyspanner
sooty
adamskibx
oscarloco
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sooty</i>
Can you only hear this noise when you are driving or only when you parked????
I only hear the sound with the car idling. At low revs (less than 1500) I hear it but then it tends to quiet down. As I said before, I think it quiets down but it could be that engine and road noise drowns it.
sooty
It could be a bearing starting to fail. One thing you could do to eliminate such as the alternator or power steering pump if fitted, is to remove the alternator belt drive belt. If the noise disappears its most likely to be the alternator bearing. If the noise still remains, it could then be a idler bearing on the cambelt tensioner.
Good luck in searching
oscarloco
oscarloco
jeremy
are you sure it isn't something like a drivebelt? My old Renault 21 made apalling noises and when I could be bothered I'd squirt it with WD40 and it would quieten for a bit - then I'd put vaseline on it when I was really fed up - this would last for a bit.
I've got a noisy one on my BX now - it goes quiet with a bit of silicon - must replace it!
jeremy
jeremy
