I did a LHM change about 500 miles back and the hydraulics were great for about 300 miles but now im starting to feel every single bump in the road, spheres i presume? Coincidence its after the change or something else?
More annoyingly, since i had a new exhaust fitted about 600 miles ago, a mettallic drone has appeared at idle (worse when cold) now i presume the exhaust isnt quite seated correctly BUT the whole engine has developed a slight "judder" too around the same time and i can feel the engine vibrations through the pedals and steering wheel much more prominantly as of late. Could this be the bottom engine mount or is a mis seated exhaust going to cause this effect?
If i hadnt done anything to the car i wouild instantly say engine mount and spheres need doing (they are on around 55k but of unknown quality as the previous owner had them done) but because of this LHM change and the new exhaust i dont want to waste cash on things that can be fixed in a different way.
cheers
