Fellas:
First of all, i want to thank everyone who helped me out with my doubts.
So, with no further adue, here's the pictures with some explanations.
This is the cruise control stalk, part number 6239NK (i bought mine at Pug, €2 euros cheaper plus 10% discount!) for €40
http://classicotuning.no.sapo.pt/CC-1.JPG
Step 1: locate the steering wheel cover bolts and remove them, along with the lower cover.
http://classicotuning.no.sapo.pt/CC-2.jpg
Step 2: locate the plug for the stalk (see how it has a small plastic cover).
http://classicotuning.no.sapo.pt/CC-3.JPG
The plastic plug cover:
http://classicotuning.no.sapo.pt/CC-17.JPG
Showing the guts:
http://classicotuning.no.sapo.pt/CC-4.JPG
Note for the small upright PCB, which interfaces to the CC stalk.
Step 3: Getting it into place gently.
http://classicotuning.no.sapo.pt/CC-7.JPG
Here it is!
http://classicotuning.no.sapo.pt/CC-8.JPG
A close-up:
http://classicotuning.no.sapo.pt/CC-9.JPG
Step 4: Cutting an opening on the lower steering wheel cover. See how there is a groove already marked in the plastic.
http://classicotuning.no.sapo.pt/CC-10.JPG
Preparing for surgery:
http://classicotuning.no.sapo.pt/CC-12.JPG
Ready after filing and sanding, plus using the hot knife for smoothing the edges:
http://classicotuning.no.sapo.pt/CC-13.JPG
Step 5: Putting it back again.
http://classicotuning.no.sapo.pt/CC-15.JPG
Can you tell it from a factory fitting[:D]?
http://classicotuning.no.sapo.pt/CC-16.JPG
All there's left to do is to take it to Citroën and tell Lexia to activate the function on the BSI. Simple!
Fortunatelly, i know a guy who knows another one inside Citroën who'll do it for me, though not very happy... -->look at my worrying face[8D]
Once more, thank you all!
Installing cruise control on a C5 - DIY
Thunderbird
adamskibx
Thats very good work- Much better than my attempt at it in my Dyane a few years ago!! My DIY cruise in that consisted of tecknic lego, elastic bands, a pully and a bit of string!! One motor to clamp the string that went in the opposite direction from the carb that the accelerator cable goes and another low geared unit wired up to a two way switch that gently inceased or decreased the throttle opening. It was quite a novelty having a crude form of cruise control in a Dyane- Think it scared a lot of people though!!
406 V6
Thunderbird
As you can see here, the Xantia wheel has 8 buttons (4 on each side) to control the radio and CD box.
http://www.lewebdesconducteurs.com/essa ... ia07_2.jpg
406 V6
AndersDK
Jon
