Snapped cambelt, Clio Diesel
p63500sv8
Unread post by p63500sv8 »
The cambelt snapped on my 1.9 diesel when travelling at about 40 mph.
What chances are that the engine is now knackered?
Is it worth fitting a new cambelt just to see or (after 5 weeks ownership!) should I throw it away and start again?
Many thanks
citroenzx
Unread post by citroenzx »
for the sake of £15 as opposed to a lot more you might as well give a new cam belt a go you never no you might be very lucky
np
Unread post by np »
Throw it away & start again.My sisters belt snapped on her Clio D last year.The engine was ticking over in traffic.After taking the head off,we found a few bent valves & there was indents on top of the pistons where the valves had hit.
Sorry[:(],not what you wanted to hear.Could just try a new belt as Citroenzx says,you never know.[:)]
reblack68
Unread post by reblack68 »
I got away with it on an Escort diesel once. Check the valve clearances, any wide clearances mean a bent valve. Normal or narrow clearances mean it's worth the bother of trying a new belt.
I got away with it because my belt shed some teeth and slipped but picked up again before anything clashed.
