Does anyone know what the correct height should be from the ground to top of the wheel arch for a '99 Xantia Hdi on normal ride setting, with the engine running please.
I think mine is sitting too high and I don't have a manual.[:I]
Xantia front height
AndersDK
Andy did a research on this subject : http://www.andyspares.com/discussionfor ... C_ID=13066
If you seem to get lost in the tables for model/year/tyre size - then you can always use the rule of "half-n-half" :
Have engine idle handbrakes on.
Now set the suspension height to HIghest height.
Make a marking on the wing using a scale
Now set the height to absolutely lowest.
Make a new marking in vertical line with the first one - from the same point on the scale.
The correct drive height would be exactly midway between these 2 markings - from same point on the scale.
Mandrake
- x 694
This method may not be very accurate, as in the high position the full pressure of the hydraulic system is compressing the top rubber snubber limit stop, so it moves higher than it normally would during a rebound, while in the low position you just have the weight of the car sitting on the bottom snubbers which will compress them a little bit, but not nearly as much as in the up position.
It may be a bit different on a Xantia (with struts and no upper wishbone) but on the GS and CX measuring the half way point between the suspension being right up and down is definately not half way between *just* touching the snubbers...and not the same height as specified in the manual. (It will be too high)
YMMV of course [:)]
YMMV of course [:)]
silverback
