ZX to 306 brakes.
DarkendViper
ZX to 306 brakes.
Unread post by DarkendViper »
I know that a popular brake upgrade for the ZX is brakes from a berlingo. I've tried to get hold of a set but can't seem to. I'vw been offered a set of calipers of a 306 XSI 16v. I know the disk size the take is 266mm. Would these fit with the right carriers?
Ste
Jon
Unread post by Jon »
Should be OK as berlingo discs are also 266mm, and the hubs are the same too.
rossd
Unread post by rossd »
They will be identical. The 8v XSi (eg before 1997) used different calipers, but the Phase 2 versions used the same as the berlingo / Xsara / Partner etc etc (Until they changed to Bosch sometime in 1999)
