Hi All,
Due to a mix up [:o)] I have a brand new front strut return pipe for my XM. Is there any benefit in replacing one of the existing pipes?
regards
sean
XM strut return pipe worth replacing ?
adamskibx
Hello Sean. If its not broken it doesnt need fixing however if it hasnt been done before it may be a good idea. My BX return pipes failed both at a similar time due to age. The rubber can only last so long due to constant movement, ageing and temperature changes. When they go, it will leak fluid slowly but when you put the car up and down it will squirt out and apart from being messy its expensive too. Id change it if youve got the time but if one is going to fail the other wont be far off.
- x 1240
sdabel
jeremy
