406 2.1 TD GLX NO SPEEDO??
chrismillie
Unread post by chrismillie »
HI THERE EVERONE I HAVE JUST BOUGHT A 406 2.1 TD THE PROB WHAT I HAVE IS THAT THE SPEEDO HAS STOPPED WORKING. SOMETIMES IT WORKS FOR A SHORT TIME THEN STOP'S. WHEN IT IS WORKING IE DRIVIN DOWN THE M6 AT 70MPH THE ENGINE MANAGMENT LIGHT COME'S ON AND THE ENGINE HOLDS BACK TAKE MY FOOT OF THE PEDAL AND BACK ON LIGHT GOES OUT EVERTHINK FINE. BUT WHILE THE SPEEDO IS WORKING THIS LIGHT COMES ON AND OF WHEN SPEEDO IS NOT WORKIN NO LIGHT AND NO HOLDING BACK FROM THE ENGINE. DOES ANYONE KNOW WHAT THE FIX IS OR WHAT ELECTRONIC GIZMO IS KNACKED?? PLS HELP ME GUYS THANKS CHRIS
PowerLee
Unread post by PowerLee »
Hi
Its either the speed sensor on the gearbox, Or more likely the speed interface unit behind the glovebox.
arry_b
Unread post by arry_b »
My money is on the speed sensor on the gearbox. I saw many of these when work bought 406s for lease cars.
chrismillie
CHEERS LADS.. DO YOU KNOW WHAT PRICE AND THE PART NUMBER FOR THE SPEED SENSOR OR SPEED INTERFACE AND HOW DIFFICULT A JOB IT IS
THANKS CHRIS.........
PowerLee
Hi
Speed interface is part number 1929 SJ & is found on the 2.1 Turbo diesel, 2 litre 8 valve turbo & the V6 24 valve.
Speed sensor is part number 6160 64 & again its the same for the 2.1 Turbo diesel, 2 litre 8 valve turbo & V6 24 valve.
Rough prices im guessing from previous dealings with these a few years ago is around £30 for the interface & £60 for the speed sensor.
Also, Have a look down the local scrapyard.
Fairly simply job, The speed sensor only has a bolt & a connector plug so that ones easy ( when you can get to it )
The speed interface is up behind the glovebox, A few torx 20 screws undo with the correct tool will gain you access to this.
Also, While your there, Is your re circ flap motor clicking? Check it out while you have great access to it.
I would also have a look at the speed sensors connection first, On the 16 valve cars the thermostat housing leaks & the drips away right above the speed sensor & causes all sorts of problems, Not sure if this is the same on the 2.1 Turbo diesel but worth a look anyway.
chrismillie
cheers mate thanks for all your help and advice and yes there is a flapping noise when i first turn ignition on i will let you know how i get on with it prob try to fix next weekend and once again thanks..
chrismillie
hi lee been tryin to fix the speedo sensor the prob that i have is mine only has two electricle pins on the connector all the ones i have tried either have three or four tried gsf gave them the year of the car there part also has three pins. is this a change over year?from mk1 to mk2? can anyone HELP PLS... thanks chris...
PowerLee
Hi
The speed sensor for the mark two 406 is Peugeot part number 6160 39
chrismillie
hi lee pls help changed speed sensor bought new one from main dealer.still no speedo so i changed speed interface still no speedo what else can it be HELP thanks chris. also tried diffrent clocks but still the same. one thing i have found though is a relay wich i think is somthing to do with the speedo is this true? and ifso will it have to go to main dealer to be fitted?thanks chris...
chrismillie
well had to take car into main dealer to fix this fault.thay found the prob there is one more elec box stuffed right up behind the glove box (NOT THE SPEED INTERFACE ? )it is located to the bulk head and is part of the ecu which is why engine light was comming in. when i asked for more info ie name and part number thay would not say? total cost was £159.08 inc vat.speedo now works fine[:D]
