lve got a 94' 306 1.4 petrol that makes a knocking noise when going round right hand bends, lve checked the wheel bearings which have no play and wheels spin freely enough with no apparent noise, lve jacked the front of the car up and whilst turning the steering wheel a noise can be heard fron the top of the struts, one side more noisy than the other, could this be the cause of the knocking noise? has anyone suffered the same problem? any help most welcomed, many thanks.
Duggie.
306 steering noise, knocking
Not sure about the struts, but a knocking when turning is often down to a split driveshaft gaiter. I can never quite remember which way round it is, but I've got a feeling that knocking when turning right indicates a dodgy left-hand gaiter. Or it might be the other way around [:D] Check both are in good condition as it's a fairly common part to perish.
Is it a regular rhythmical knock (driveshafts), or random (drop links or strut top bush)? The gaiters themselves won't knock, the bits inside of them do. The damage is usually caused by not fixing a split gaiter, which is cheap to fix; and the ensuing debris that gets into the joint wears it badly, which isn't.
