im just cross posting in here cos you guys are a lot more active (and have more spare parts lying around then in the pug forum)
I need a spring for a rear brake pressure regulator for 405 estate (m reg).
I just want the spring not the whole unit as the nice man from peugeot says it £73 +vat
I have been reliably informed that there is a comparable spring on a citroen but no idea which one. And id be happy for one of those too.
Or does anyone know where i can get a new one cheap???
cheers si
rear brake pressure regulator.
jeremy
vanny
Ha, reliably informed. I said there MIGHT be one! It wont be on a hydraulic cit thats for sure. The spring seems to hold a big flap closed on the back of the ABS regulator, not strictly sure what it does as the 405 isn't hydraulic and is therefore WRONG!
Having checked the parts lists, the Berlingo has almost an identical thing, but again you cant by the little thin spring without buying the whole damn pressure regulator. But it does suggest however that i might be possible to use the spring from a Xsara maybe?
caveman_si
