Xantia 1.9 TD Towing
soupy_sam
Unread post by soupy_sam »
Is there anything I should know about or do to my Xantia 1.9 TD before towing a folding caravan with it.
Kowalski
Unread post by Kowalski »
Fit a towbar?
Check that your water and oil levels are correct. Check your hydraulic fluid levels maybe the gearbox oil level too. A folding caravan isn't a big heavy thing to tow so beyond normal maintenance there isn't a lot to be done. The car will get hotter when towing so you want to make sure that your cooling system is working optimally.
fastandfurryous
x 4
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>
Fit a towbar?
LMFAO!! [:D]
soupy_sam
What weight will 1.9 TD tow and what nose weight should I watch for????[?]
martyhopkirk
Unread post by martyhopkirk »
1.9 TD will comfortably tow 1200Kg - however this is nearing 100% of its Kerb weight - If you are a novice tower dont pull more than 85% of the cars weight (about 1100kg max) -
I recently pulled about 1600kgs with the 90BHP HDi Xantia - but then Im have a lot of experience towing and made full use of the HP suspension set up on the Xantia - no way would I have done it with the equivelant 406.
The towball weight should be between 50 and 75KG (75Kg maximum).
Check this website for all Cit towing weights...
http://www.cuddles.abelgratis.net/citroen.htm
nick
Unread post by nick »
I once towed a 5.3L V12 Jag for about a mile with a BX 19RD - not something I would try again in a hurry [:D]
np
Unread post by np »
Our caravan has a all up weight of 1300 kgs.On the 85% rule of thumb we tow at about 93%.Never had any probs at all.Still has the same spheres since getting the car 46k ago.
I put my car on the weighbridge at work once with nothing in it & the fuel light on.It was 102kg`s heavyier than the book says.
Max nose weight is 75-85kg.Less for estates.Every where gives different limits i find though.
soupy_sam
Where can I get my car and caravan weighed
pwatson
Unread post by pwatson »
Quick Google revealed this - hope it's of use
http://www.yell.com/quickclicks/SP/W/We ... /Coventry/
