Iv'e got a cd player for my Xantia its not a genuine citroen but a kenwood can someone tell me where they fit the cd changer on the xantia estate is it in the back or under a seat.
thanks
where to fit the cd changer
Dave Burns
This may not be appropriate for the estate version, but I made a steel box from 1/8th plate at work and put a five lever safe lock in the lid.
The suspension mounting bolt's on the Xantia protrude a good distance through the nut's, so I made some extensions to screw onto them and bolted the box down onto those extensions.
CD changer is protected from shock's because the box is lined with thick foam rubber, its also protected from any load's carried and is as theft proof as it gets.
The car can't be driven away because of the coded keypad so I am confident about also using it for the safe keeping of things like wallets and the face from the head unit while I'm away from the car.
Dave
Dave
roscopervis
JohnD
- x 72
