Laguna 1.9 DTI 1998
JohnnyM
Laguna 1.9 DTI 1998
Unread post by JohnnyM »
Back again after the turbo problem. On the instrument panel the Serv and the injection warning lights come on and I lose acceleration. This has happened on and off for the last 2 yrs. First time Renault changed an injector but recently I was told it could be the EGR valve, which I had changed (£130). However after 4 weeks of no problems, its back again. Any suggestions![:(!]
ralphm
Unread post by ralphm »
I have the same year DTi and had the same problem for some time. I believe that it is due to vibration in the injector pump region. Check all mounting bolts for the injector pump and alternator assemblies. One of the bracket mounting bolts worked loose on mine this led to 2 others snapping in the cylinder head. To cut a long story short, the timing belt jumped off causing over £1100 worth of damage. The warning lights have now stayed off (hopefully). Hope this might be some help to you.
JohnnyM
Thanks Ralph, if it works I wonder how long a dealer would have spent charging me to find that out.
Johnny[:)]
timmyl
Unread post by timmyl »
I don't know if this helps but... My dTi, same symptoms, service & ECU light coming on, losing power. Turned out to be crap in the fuel swirl pot in the tank. It's accessable through the boot floor, easy but smelly job!
