Xantia HDi faster than CX 2.5 GTi
Thunderbird
What a surprise... [:D]
- CX 2.5 GTi (84 on) 140HP, 206Nm, 201Km/h
- Xantia 2.0HDi Upgraded (1999-2001) 136HP, 293Nm, 202Km/h
Never imagined the CX GTi was so slow. [xx(]
VisaGTi16v
VisaGTi16v
DoubleChevron
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Thunderbird</i>
Nah, your using the wrong CX, my old CX GTi is still hauling effortlessly at 220km/h and will accellerate nicely if you put your foot down.
If your HDi is seriously putting out 293Nm of torque, no doubt it's top speed and acceleration should be higher.
I still think my old bog standard old CX will effortlessly leave any standard Xantia (even the V6's) for dead. You could probably watch the fuel guage dropping though if your decided to sit on 140mph though[V]
seeya,
Shane L.
seeya,
Shane L.
Thunderbird
What you see marked on your car is not the real speed. If that was the case, than I could say my Xantia HDi "flies" at 230Km/h.
Those specs are for CX GTi mk2 (2.5 engine). The previous GTi was even slower:
Mk1:
- CX 2400 GTi (77 on) 130HP, 197Nm, 189Km/h
Mk2:
Your car best score is 189Km/h. [xx(] You call that speed?! [:0]
Comparing to a Xantia V6 manual:
- Xantia V6 (98 on) 193HP, 265Nm, 235Km/h
Note that at 235Km/h the Xantia marks around 255Km/h.
Now, a CX GTi Turbo 2 is another matter, yet nothing special.
Mk1:
Mk2:
pagh
VisaGTi16v
agreed but I would say the best figure is 30-70 thru the gears which is probably the most common closely followed by 50-70 in top gear. You dont often do 0-60 thrashes unless youre a boy racer or you compete. My Visa is geared to 137mph in 5th which is a couple of mph too high for the events I do but it will do for now. Plan to swap to a 6 speed box in the future which will give 138 in 6th but then 5 evenly spaced gears below it.
DoubleChevron
Mk1:
Mk2:
Did I forget to mention it *is* a GTi <i>Turbo</i> [:D] [}:)]
The only car I know of that matches them is the 160hp Series I BX16valve (about 7.8seconds to 100km/h). I'm not sure of top speed, I backed off at about 220km/h and it was still pulling hard. The V6 slugomatic Xantias aren't quite that quick I don't think.
seeya,
Shane L.
Mk1:
Mk2:
seeya,
Shane L.
Kowalski
ActivaV6uk
Thunderbird
ActivaV6uk
