Hello, I followed the haynes manual instruction on how to deactivate airbag system, although i diconnected both terminals on the battery (is this okay?),so i could replace front seats. Unfortunatley i did not follow he correct activation procedure and now have a flashing airbag light. I just conected the battery back up and started it and the bag light keeps flashing, is it broken?
Ive just diconnected the battery again and ill leave it for 10 minutes and try following the procedure.
Any ideas?
Thanks.
I Think i broke my airbag :-(
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Hi
First thing is, If the airbag light is flashing or on then the whole SRS system is disabled & WONT fire if you have an accident.
What are you trying to do here & also what car is it on?
You said you are replacing front seats?
Do the replacement seat have pretensioners fitted that are ok?
You can swop pretensioners between seats they are only bolted on, Use thread lock on the bolt & dont lose the wavy washer under the bolt head.
But if the seat you are swopping them to never had pretensioners fitted then you need to swop the half C bracket over as well (Just riveted on)
If you have fitted after-market bucket seats & harnesses then you need to get the dummy plugs to fool the SRS control box so it thinks the pretensioners are still there.
Can we have some more information please?
Past:
Hi
You cant really check a pretensioner to see if its ok, They either are ok, dead or fired, Are the phase 2 pretensioners about 4 inches shorter in height then the originals fitted to your car?
What ever you do, DONT try & use a electrical test multi meter on them! If you connect a test meter to a LIVE pretensioner it will FIRE!
The pretensioners from the phase 2 might be diffrent inside then the phase one pretenioners, There was a few different kinds of pretensioner fitted to the 306 according to the part cd rom.
Just swop them over, Its only a 17mm bolt that holds them on & they tuck into the C shapped bracket on the seat frame, Also dont lose the wavey washer under the bolt head.
