Pinout Needed
rossnunn
Pinout Needed
Unread post by rossnunn »
Hi all,
I'm after the pin out for the engine loom on a 306/Saxo 1.4 Multipoint.
Cheers
R
vanny
Unread post by vanny »
pin out for the loom or the ECU? What year?
ActivaV6uk
Unread post by ActivaV6uk »
hehe if you can get eather me or vanny the year we both have ways of geting this info also for any other Citroen.
Andy
rossnunn
no, I have the ECU's pinout, its the connecter into the body loom, on the nearside inner wing, two round plugs
ActivaV6uk
We wont be able to help you with the main loom.
Sorry
Andy
rossnunn
damm ok lads, out with the meter then
Cheers
ActivaV6uk
What is the problem if its a specific system i may be able to give you the wire number.
Andy
rossnunn
Its connecting up this Multipoint into the ZX. The engine came out a '96 306 which uses twin round plugs down on the inner wing, the Single Point uses a single round plug, up under the under-bonnet fuse box. Short of changing the entire underbonnet loom for one out of a 306...
I'm going to look up the breakers to look at other looms. I've seen the 1.4 Multipoint in a saxo uses a single plug.
