throtle cable
toldem_oldham
throtle cable
All reet peeps!!!!! got a xantia td lx estate recently and the accelorator seems to b stiff it revs up ok but revs are slow to decrease when foot is off the accelorator.Ive realeased the cable from the fuel pump and this seems to be free backwards and forward could it be down to the gas strutt on the pump been at fault or is it somethin more sinister? oh it only does this when the engine is warm,when first started the engine revs correctly [?]
oilyspanner
Firstly check the routing of the cable under the bonnet, see if the thing is being trapped or is running in any tight curves that can be avoided, the gas strut can be safely removed to see if its at fault, AFAIK it was originally fitted to slow throttle closing and make the engine braking more gentle.
Stewart[:D]
Stewart[:D]
toldem_oldham
Thanx oilyspanner if it is faulty can i get 1 from a motor factors or is it a visit to the dreaded main dealers [:(!].As for the cable been obstructed ive checked and it is clear of kinks and nothing seems to be interfearing with it.i dont know y they couldnt keep em like the 1ns on the pug 405 td spring operated,much less maintainence but thats bosch for u init.[B)]
oilyspanner
toldem_oldham
RichG
toldem_oldham
toldem_oldham
