Hi Folks
got my zx on the road and the alarm is doing my head in, it just decides to go off after 20-30 mins.
I cant be bothered to fix it, so id rather jus switch the damn thing off so i can still use the remote fob.
i cant find a key switch anywhere.... any ideas how i can disable the alarm.
there seems to be a unit near the passenger side front wing but i dont fancy removing this to have a look
any help would be appreciated. Thanks.
alarm problems on the ZX!
Brian Oblivion
AlWilliams
I've just stripped down an N reg ZX for parts, it had a factory fit alarm, and found the alarm sounder mounted to the front valance under the driver side headlamp (behind the bumper).
The blighter went of when I disconnected it, I found the best way to stop the noise was a decent screwdriver and a big hammer. There only plastic.[:)]
If you have a key operated switch in the front under the bonet your ignition key may fit, it not, get that screwdriver again and using a bit of force (mole grip or the like) turn the key slot with it.
Hope this helps.
Hope this helps.
zxb29
VLL
AlWilliams
Ah,
Right, another approach. If you can have a look under the bumper in front of the passenger side wing you my find the unit there. Being it sounds like a aftermarket job it may have the disarm key lock actually on the alarm itself.
Forgot to say in my last reply, only use force if its just an alarm. If it's and alarm and immobiliser, that's what you may be, immobilised.
zxb29
oldnail
If its a three door SX the alarm contol unit is behind the panel under the passenger side rear window.Remove the torx screws that hold the panel in place pull the panel clear you will see the unit attached to the car body by three more screws.remove the unit, pull off the two multi plugs,problem solved.Everything else still works the same ie cental locking etc but no more annoying false alarms.You can now either fit a decent aftermarket alarm or just use the keypad immobilizor.I would'nt waste hours trying to get the original to work properly as it will always let you down in the end.We've had a '97 TD SX from new and the alarm has never been 100% reliable from day one.Bin it!!!!!!!!
Apart from that the best car I have ever owned.
James.UK
zxb29
OK i had a look today weather was good but too good to do any work on the car so will leave it till tommorow.
On the side if u you remove the indicator lamp there is a torq screw and a look from the bottom shows 2 nuts prob 10mm holding it place. can i remove this bolts/screws and slide the unit out or will the wing have to come off. OldNail its a 5 door SX and yes its a really nice car. sounds more like a petrol then a diesel. but i miss my nippy turbo diesel aura
Forth
oldnail
If you just want to disconnect the siren remove the nearside sidelight, look up between inner and outer wing and you can see a multiplug.Remove plug with suitable long screwdriver and this disconnects the siren.Then if the alarm goes off just the lights flash.You may also find the red neon under the clock stays on all the time,mine did.
Forth
zxb29
