Distributor cap and arm set?
Flynn
Unread post by Flynn »
GSF list a distributor cap/rotor arm set for the 405 Mi16 (Duceiller 88-92 Male End/Screw-on P/N T92162)
Anyone know if this is the same as the Duceiller cap and arm on the BX 16v and suitable?
Flynn
*nudge* ;)
AndersDK
Unread post by AndersDK »
I tried a search for a Ducellier usage or cross-ref table on the web. None found. Donno on this issue.
Jon
Unread post by Jon »
I don't think that its a set, the cap and arm are seperate I believe.
You need an N92110 dizzy cap and N92210 arm suitable BX 16v and Mi16 1.9.
jeremy
Unread post by jeremy »
My 93 GSF catalogue lists : BX 16valve Ducellier 88-93 N92118 £25.00
405 Mi16 - Ducellier 88-92 T92162 £25.00
Have a look at this link - its the complete catalogue from a Quinton Hazell subsiduary and if i read it correct their version does fit. http://www2.qha.com/catalogues/ZC1-01.pdf
QH are publishing a number of catalogues as downloads - and its worth looking at their site. I see they even do bottom hoses for BX TD's!
jeremy
Flynn
Thanks all. The bit confuses me is that the GSF catalogue shows distributor cap/rotor arm set for Mi16 at £25.00 but bought separately for BX 16v as £25 + £26
cornishbx16v
Unread post by cornishbx16v »
I normally buy mine from the local factors and pay about £25 for the pair but that is heavily discounted!! the arm is normally £18 and the cap is around the £25 mark!
