WHAT IS THAT CLICK.....
mezuk04
Unread post by mezuk04 »
.....That happens once everytime I do the front electric windows up for my drivers side.
Regards
x 1238
Unread post by Peter.N. »
My wife's car does that, it sounds like the central locking on he rear N/S, it's never caused a problem so havn't persued it, probably a high resistance earth connection somwhere
basil
Unread post by basil »
My drivers window has a click when it reaches max open/closed position .I assume this is to do with the 'one touch' fully open/closed operation.
________
Design Host
alan s
RIP 2010
x 6
Unread post by alan s »
We get it also on one of the BXs. I've singled it down to the relay that is operating on the window so now the job is to find if it's the relay contacts sticking or the switch.
In our case, if it is left go, it will do an od click at a reasonably consistent time and when you try to wind the window down it often won't go until you wait for a while which suggest to me it either jams the window or there's a circuit breaker involved.
However, when we wind the window up using the auto to the top switch it will do it every time until we have to just flick the down switch whereupon it doesn't make the noise. The switch is my prime suspect.
One of those jobs I'm always 'gunnado'
Alan S
