When I try to switch the AC on or the internal circulation nothing happens, I have no fans and am unable to change the temperature setting.
I've checked all the fuses in the passenger conpartment and all seem ok. i've also checked to see if any connectors are lose and couldn't see anything.
It was imtermittant for a few hours before it stopped.
I have a 99 (T) Dturbo 306.
Anyone know of possible reasons why these are not working? Power is being sent to the rear heater, hazards and stereo fine.
Any help would gratefully be received. Thanks[:)]
306 TD heater controls/AC
grattsim
I've let a peugeot mecahnic look and he couldn't find the problem in the hour I allowed. He expects it could be a connector as the unit doesn't seem to be getting any power.
Does anyone know the locations of the connectors/wiring leading to the temperature and blower control dash?
Would mine be linked to the ignition switch as well?
Any known problems with these?
I've been lucky so far that I haven't been misted up, but this something I really need to sort. I don't really want to let it lose on the interesting people at the local Peug dealer.
Linchpin
grattsim
grattsim
grattsim
Has anyone had their switches fail?
Everything else seems to be fine. Theres no power going through the fuse, but I have found power in the connector in the passenger foot well. Therefore I am assuming that the switches have failed and therefore no power would be through the fuses.
I'm sure someone out there most know the answer.
Thanks Simon
Thanks Simon
grattsim
I thinking from looking around that this is a common problem, but no one seems to have the answers. There must be a bright person in the know.
I would like to know any ideas out there along with the other people still trying to solve the problem.
So far, its not the relay, connections, resisters.
Is there a problem with the wiring loom? Circuit board?
HELP!
HELP!
grattsim
